2006 30 Outlaw Stereo >
Old 06-15-2009 | 08:46 PM
Elite Marine's Avatar
Default 2006 30 Outlaw Stereo
My friends 30 outlaw has some radio issues. When running at speed all the speakers work and its fine, but when at anchor the cuddy speakers work and the cockpit speakers dont.
I'm sure its either a voltage issue or something simple. Firing the engines and at idle did not help.
Is there a seperate amp for the cockpit and cuddy speakers? Is there an amp at all? If so, where is it?
Thanks,
Kirk
Elite Marine is offline
Old 06-15-2009 | 08:59 PM
On my 23 outlaw, I had a similar issue. The cuddy speakers worked, but the cockpt speakers never worked. The problem was the amp blew and the some wiring needed to be changed.
Donzi Andy is offline
Old 06-16-2009 | 08:30 AM
MillerLite88's Avatar
Charter Member # 90
there is an amp or piece of amp in the head. Open the panel behind the toliet and there is an amp of some sort if you want to call it that......
-Shoe
MillerLite88 is offline
Old 06-16-2009 | 12:23 PM
Mine is set up weird too. My amp is wired to an accessory switch on the breaker board and always trips everytime you turn the stereo up loud. I've never seen am amp wired to a breaker board. Usually it goes straight to the battery. My amp only runs my cockpit speakers and subs.
hoff2483 is offline
