Lencotrim tab?
i have lenco tabs on my 03 checkmate.
last year i had no issues. this year i had the port side led's on the switch go out. both tabs still worked fine.
then a trip or 2 after i had one of the tabs stick on when i shut the key off. i shut it off and the tabs go up and one stuck running. i killed the battery switch and it stopped. didnt happen again.
last time i went out, none of the led lights worked and only the star tab would work.
any ideas?? i spoke to one guy, he said its probably the pad/switch. any ideas?
i called them, they said it might be the switch, it might be the box and a small chance of it being the tab motor. told me to start with the switch, i was just hopping someone might say skip the parts changing and this is it.
it is the led version? theres a lot going on in that box, it seems like there are different problems that arise from different things. the last issue we had they actually could not figure out as i said, two bad boxes
