wont shift into reverse
hey guys i got a used shifter from one of my neighbors and it is the same exact thing as i had. a quicksilver top mount. i installed it today using my same cables and it wont shift into reverse. doesn't engage it, it just throttles up. any ideas thanks
It sounds like either your cable is broken or the shifter needs to get adjusted on the back shift bracket in the boat ,,,where it sep. the actual shift and throttle cable !!!!
I just adjusted my friends Bravo 3, his would not go into reverse. Do a search on this site. There are a couple of good post that will lead you in the right direction. All I had to do was adjust the shift cable. Since you replaced your throtle you may have somthing else wrong.
Hey, another CNY guy! I know nothing about your question though, sorry.
sorry guys its an alpha 1. and i looked at it today and i know it has to be an adjustment but how do i do it? is there a way to adjust so there is more cable or an adjustment on the shifter? thanks!
hey whats up fellow CNY'er I'll be out there soon! (hopefully)
get a copy of the service manual and follow the directions to the letter. if you are going to try to outsmart the proper precedure on an alpha it may never shift. also if you do it exactly right and the unit is worn inside, you may never get it to shift properly without disassembly. but that is always a last resort. I've adjusted thousands of these. read the book!
There will be a barrel adjuster that is held in place with cotter pin. Remove the pin and turn the barrel 1 turn forward and then test. Keep doing this until you have reverse. This is a very touchy adjustment. I about pulled out the hair on my head trying to figure this out about a month ago. Once I did it was easy. Note that you may need to fine tune it again once the boat is in the water. by the way, the adjuster is on left side (facing engine)of the riser elbow. good luck..
good luck and be safe
bobbo
cables stretch, I just had to re adjust my 20 year old formula cable. It happens. If you ride a bike, think of how much you need to adjust your cables (all the time). If your a sailor, how often do you need to tune your rig (few times a season). How often to power boaters adjust there shift cables, not until is doesn't work. Its just the nature of the beast!
