left/right rotation >
left/right rotation
left/right rotation
Old 06-22-2009 | 03:54 PM
Default left/right rotation
stupid question
which is which, looking at front of engine.
mine rotates clockwise looking from cockpit.
is that right hand.
is the right front cylinder [looking from the cockpit ]
# 1 and distributor cap order and firing order the same
regardless of rotation
nsformula is offline
Old 06-22-2009 | 03:56 PM
Originally Posted by nsformula
stupid question
is that right hand.
Its a standart rotation LH !!!!!!
But /or and yes,,,,,,that cylinder is #1
DareDevil is offline
Old 06-22-2009 | 03:58 PM
That should be standard rotation. Yes from the front of the engine, the number one cylinder is on the right front. The order should be 1-8-4-3-6-5-7-2. Make sure your start your wiring with the number one piston up and both valves closed. Otherwise you will be 180 out and it will not run well.
Scarab9626 is offline
Old 06-22-2009 | 05:46 PM
thanx guys
