Mirage Plus Sleeve, does this look correct. >
Old 06-22-2009 | 08:21 PM
Default Mirage Plus Sleeve, does this look correct.
Is this sleeve missing something? The ones I have had before are soild. It looks like this only rides on the splines you see in pic. I put it on a spare drive and it seems like it would work but it just dosent seem correct.
1BIGJIM is offline
Old 06-22-2009 | 09:09 PM
rchevelle71's Avatar
That is a flo-torq hub, seems complete, but cant tell from all the grease.
rchevelle71 is offline
Old 06-22-2009 | 09:30 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
It's correct. There is also a forward adapter if you wish to use it. Call me and we can explain all the options.
[email protected]
bbladesprops is offline
Old 06-22-2009 | 09:32 PM
I know its a flo-torq hub, I have had the HP sleeves on my other props, these came with a boat I purchased. The last 3-4 inches where the grease is dosen't touch the shaft, only the spline part. Something just dosen't look correct.
1BIGJIM is offline
Old 06-23-2009 | 05:07 AM
c_deezy's Avatar
Looks exactly as it should.
c_deezy is offline
Old 06-23-2009 | 07:31 AM
noyzee's Avatar
mine has a little plastic piece on that end that pops in and out. it takes the side you are showing wide open, and inserts in there to make it fit round on the shaft. its maybe 2" long has a slight taper. i'll see if i can find a pic of it. looks to me you are missing that piece. mine falls out when ever i take the hub out. and when i bought a new one, it didnt come with it
noyzee is offline
Old 06-23-2009 | 07:33 AM
noyzee's Avatar
to me it looks like you are missing this piece.
http://www-alt.mercurymarine.com/PXI...t/6408_reg.jpg
noyzee is offline
Old 06-23-2009 | 09:39 AM
That would offer some support at the end of the shaft.
I did not see that in my bag of parts that came with the boat.
I am going to leave the old mirage props on until I get this resolved.
1BIGJIM is offline
