crane 731 cam question for distributor gear >
Old 06-23-2009 | 12:04 PM
Default crane 731 cam question for distributor gear
i have posted about this before but the titel for for the cam gear and i didnt get allot of feedback and since then i have gotten more info on the cam. the description i read for the crane 731 and other crane cams is that they used a cast gear on it for the distributor so that a bronze gear is not needed. now they mad a black colored cam and a bronze colored cam, does the cast gear description go for the both of them or only the black one? i would call their tech support but crane is no longer around... thanks!
regalman4925 is offline
Old 06-23-2009 | 12:14 PM
Not sure about the black versions, but mine was the bronze/copper finish and it had the cast gear. I ran the stock distributor gear.
Griff is offline
Old 06-23-2009 | 12:16 PM
was you stock gear from a roller cam originally or was it a flat tappet? i remeber talking to you about it but i wasnt sure after what i was reading. thanks griff
Old 06-23-2009 | 12:17 PM
Originally a flat tappet cam.
Griff is offline
Old 06-23-2009 | 12:20 PM
well in that case i should have no issues with it then. thanks again griff
