Bravo 1 lower unit leaking oil? >
Old 06-24-2009 | 06:36 PM
Default Bravo 1 lower unit leaking oil?
Oil is dripping out of lower unit it is coming out of 1 of the three holes on the side.What is causing this?What do I need to do to fix problem?
crowntow is offline
Old 06-25-2009 | 01:19 AM
Coming out the water intake holes????????
If so, its most likely a bad seal between the drive upper and lower.
Griff is offline
Old 06-25-2009 | 06:16 PM
Thanks,I will take lower off and check.
crowntow is offline
