Lightning headers,need repair , 454 needs repair , 502 needs repair
set of used lightnings, are leaking at flange between inner and outer pipes, need flanges welded up and
decked flat. Great deal for someone who knows how to weld.
Originally cherry red but I painted them with mercury racing blue. Unfortunately they got scratched up when I pulled engine.
$550 shipped anywhere in the 48 states
Gen6 454 shortblock , 4 bolt mains, windage tray,big Merc oilpan ,cast crank,cast rods, forged GM pistons (not original) ,
roller cam from 502 EFI Mercruiser , gm roller lifters , adjustable timing set, cam set 2deg retarded , one rod spun a bearing, will need rod and crank turned, all engine is still standard, no oversizes ,rest of engine is clean and in excellent shape.
As-is $500 in austin texas. Shipping is all on you.
will wait till monday before putting it on craigslist and ebay.
Gen 6 bowtie roller 502 block, J&E forged pistons , dimple rods , forged crank , line bored,balanced, honed , everything done top to bottom by "The Cylinder Head Shop' here in austin. Comes with flywheel and balncer used when engine was balanced.
With less than 10 hours Water got in to a cylinder and bent a rod and upon taking it apart we found a crack in one cylinder bore. Will need one rod and one sleeve to make it right. $500 here in austin texas , shipping is all on you.
my shop is 3206A Rainbow Hollow ,Lago Vista , Tx 78645
(and for anyone that may use this knowledge for "other" purposes keep in mind its a closed neighborhood ,one way in,one way out,and it perfectly legal to shoot here)
I'd love to get the lightnings if they're still avaiable? I'll look into shipping prices of you are able to ship them to Australia?
Please don't shoot me!
