Throttle Positioning >
Old 06-29-2009 | 04:13 PM
Default Throttle Positioning
What would cause the need to have one throttle stick slightly (less than 1/4") more forward than the other at any speed in order to keep the RPM's equal between the pair of 496HO's in my 30 Outlaw???? Is it adjustable?
Thanks.
imartin is offline
Old 06-29-2009 | 06:29 PM
They are all like that because of the prop torque and the way stuff handles with load etc. Don't believe there is anyway to adjust it..
Irishtornado is offline
Old 06-29-2009 | 09:44 PM
Smitty's Avatar
Yes there is an adjustment either at the engine end or the throttle end. As the cables age, they stretch so figure out which one needs to be moved a little and tighten up the play in the cable.
Smitty is offline
Old 07-01-2009 | 12:21 PM
Makes sense and being that I am not much the mechanic, will have to have that looked at. Thanks!
imartin is offline
Old 07-01-2009 | 12:26 PM
Words of a very wise man.
Baja_man is offline
Old 07-01-2009 | 03:13 PM
Dock Holiday's Avatar
Charter Member #34
The number one reason is that your props are not matched!
I have never had to adjust the sticks on my boat once I got a set up props labbed and perfectly matched. Stock props out of a mold are not perfect adn no two molds are identical. I have seen as much as 300 RPm difference in engine speeds with stock props requiring the throttles to be at different positions to have both engines running at the same RPM.
If you have stock out of the box props have them matched up by a good prop shop like BBlades before you start adjusting the throttle cables. If not you could loose top end RPM on one engine after the adjustment.
Good luck
Dock Holiday is offline
Old 07-01-2009 | 04:05 PM
Custom Interiors & More
Dock,
Have you ever noticed that a well matched engine/prop setup on a twin engine boat tends to gain speed after the first 1-2 miles, and a mis-matched setup tends to hit a "brick wall" at wide open?
XT
XT-Innovator is offline
Old 07-01-2009 | 04:36 PM
Charter Member #34
Originally Posted by XT-Innovator
Dock,
XT
Yes Sir
There is nothing like a matched set of props on a boat. I compare it to an unbalanced set of blades on a mower.
You can tell a difference and it is smooth and sweet.
Old 07-01-2009 | 10:33 PM
crayolacrazy's Avatar
Originally Posted by Dock Holiday
Yes Sir
There you go again GRASS on your mind
crayolacrazy is offline
Old 07-02-2009 | 07:44 AM
JasonSmith's Avatar
Yes Sir
So you can balance the 9 blades on the 16' cut Jacobsen? How about on the 10' Toro?
JasonSmith is offline
