Will these swap??? >
Will these swap???
Will these swap???
Old 06-30-2009 | 12:10 AM
Default Will these swap???
Sorry I don't have access to the prop talk section.
So I have SSM II's with 19 spline long shafts. Someone told me that they thought the II's could take Bravo props.
Can anyone confirm or deny this before I go ordering new stuff.
Thanks!
bigo181979 is offline
Old 06-30-2009 | 10:14 AM
JasonSmith's Avatar
Thanks!
Call Bblades.
JasonSmith is offline
Old 06-30-2009 | 11:02 AM
The Bravo's do not fit as far as I know. The 19 spline props are used on Speedy 2, 3's, Arnesons, etc. The are not easy to find.
Wannabe
wannabe is offline
Old 06-30-2009 | 01:30 PM
Rookie's Avatar
Wannabe
And they are expensive, I think a bravo is a 15 spline.
Rookie is offline
Old 06-30-2009 | 07:45 PM
I believe Arneson make an adapter hub to fit a Bravo prop to the 19 spline. It's worth a call.
Darrell.
DMOORE is offline
Old 06-30-2009 | 11:57 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Darrell.
Thanks.
I can put the Bravo propeller onto your drive, however how you will address the difference in hub diameters is a harder one to solve.
The Speedmaster is a few inches less in diameter than the Bravo propeller is and thus there will be a lot of drag.
I make a propeller adapter that will allow you to put a new SSM#6 style propeller onto your drive which will be the more logical choice.
Rik
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 07-01-2009 | 11:27 AM
Originally Posted by Rik
Thanks.
Rik
Yeah... I am trying to get to less expensive props lol. but thanks for the info!!!
Old 07-01-2009 | 07:32 PM
What's the spline count for the outboards? Are you looking for cleavers? Seems that they are much less than #6 props.
Darrell
DMOORE is offline
Old 07-01-2009 | 11:34 PM
Rik's Avatar
Rik
Darrell
This was my idea about 6 yrs ago and I found the outboard propellers have to little blade area for a boat with any size. I have done several adapters for 18-25' small V's but on a larger boat they have a bit to much slippage so you have to compensate for the slippage.
They are limited to a 15" diameter + - a little and depending upon the boat, some of the smaller pitch ones (Pro ET) are only available in RH rotation with limited pitches.
Rik is offline
