Kaama Surface Drive  HELP ! >
Old 06-30-2009 | 11:53 AM
Default Kaama Surface Drive HELP !
I have a 40' Formula with Kaama Surface Drives. I severly damaged one when the bearing came apart. I am looking for information on these unites or parts.
Formula SR-1 is offline
Old 06-30-2009 | 07:13 PM
BigBlocks's Avatar
What bearing went bad and where is the damage. I had a Kaama boat a few years back and the bearings in one of the transom assemblies went bad. The assembly got all torn up so I removed both off the boat and had a machine shop make a sleeve for the torn up one, using the good assembly as a template. It worked well and I never had an issue with it!! Not sure if this helps or not!
BigBlocks is offline
Old 07-01-2009 | 06:53 AM
It sounds like i have experienced the same damage as you did. I like your idea. what was the turn around time and the expense of the repair ?
Old 07-01-2009 | 08:51 AM
BigBlocks's Avatar
It was so long ago I don't remember what the cost was (few hundred dollars maybe). The turn around time depends on the machine shop you take it to. If I remember correctly it took my shop about a week to get it done. I pulled the drives and transom assemblies out myself!
Old 07-02-2009 | 05:51 AM
Your advice has proven to be very helpful. It looks like we will be out about 2 weeks. We are not sure of the cost at this point but still very pleased with the interest in the repair and the cost will be what it will be. All this being far better than nothing. Through this whole process we have assembled a group of people that could possibly produce casting molds for the housings and the rubber boot. We'll see. Thanks again for your help
Old 07-02-2009 | 06:23 AM
Audiofn's Avatar
Charter Member #232
There are a few boot threads going in the Formula area. If you find something boot wise let them all know and you can probably get the cost down per unit.
Put your best foot forward!
Audiofn is offline
Old 07-02-2009 | 06:38 PM
I see you bought "Wavewalker". I had been looking at that boat before I bought my 402 SR1. Cool boat!
MILD THUNDER is offline
Old 07-08-2009 | 09:15 PM
I need a boot for a kaama.
showtime83 is offline
Old 07-09-2009 | 05:25 AM
Contact Dan at Team Archer Marine 1-949-646-9778 if anyone would have one or could find one it would be Dan
Old 07-09-2009 | 05:30 AM
How do you like your 402 ? and do you have photos of your boat. We really are happy with Wavewalker.
