best air/fuel ratio >
best air/fuel ratio
best air/fuel ratio
Old 07-01-2009 | 07:59 AM
hoozeyurdaddy's Avatar
Default best air/fuel ratio
What is the air/fuel ratio you should look for at the different throttle settings, Idle, cruise, full throttle.
hoozeyurdaddy is offline
Old 07-01-2009 | 08:06 AM
tmdog's Avatar
From my study. Optimum - 12.8 peak torque
Optimum -13.2 peak hp
tmdog is offline
Old 07-01-2009 | 08:08 AM
Smitty's Avatar
That depends on if the the motor is supercharged or normally aspirated.
Tell us what setup you have and then we can advise accordingly.
Smitty is offline
Old 07-01-2009 | 08:19 AM
622CI, 12/71 mooney, 8 psi boost, 30 deg. timing locked out,
2-1095 king demons, alum, heads, full jessel valve train, CMI 4.5 in E-tops fully dry, looking to run it around 5500 - 5800 rpm
Old 07-01-2009 | 10:14 AM
tmdog's Avatar
You can throw my numbers out the window. My opinion was for a n/a set up.
tmdog is offline
Old 07-01-2009 | 05:38 PM
I have a post here with the info you are looking for. Look for "Wideband O2 upgrade".
jeffswav is offline
Old 07-01-2009 | 09:28 PM
Smitty's Avatar
You want to be around 13-1 at idle and as you go up it needs to richen up so that you end up around 11.8-1 at your max rpm.
Smitty is offline
