496 Mag Ho Won't Rev Up
Old 07-01-2009 | 11:53 PM
Default 496 Mag Ho Won't Rev Up
I have a 496 MAG HO's I just installed in a boat and they have been sitting but properally stored. They start and act like they run fine put the motors in gear and go once they BOTH get to 2800 rpm they shut down. Its not the props just so you know it acts like a limp mode or low fuel pressure. Can anyone help with somewhere to start looking.
imagecat is offline
Old 07-02-2009 | 12:00 AM
What percentage of power is available at start up? What about when you get to 2800? Do you for sure know the state of the fuel supply in the tank and filter(s)?
Did you put a pressure guage on it?
SDFever is offline
Old 07-02-2009 | 06:45 AM
New filters tanks are imco's built in 08. I really think it's some sensor or wires I have hooked up wrong but not sure. No pressure gauge hooked up.
imagecat is offline
Old 07-02-2009 | 02:41 PM
Just a thought?, did you check the oil level in the drive reseviour?, I had a similiar problem with my old heap, when the drive oil gets to a certain level in the resevior there is a sensor that limits RPM
Easy fix, so, I hope this helps!
Michael
n20michael is offline
Old 07-02-2009 | 06:44 PM
Both motors have 45lbs fuel pressure when switch is turn on.
imagecat is offline
Old 07-02-2009 | 06:49 PM
When your drive resivors are low you also have an alarm going off? When I first hooked up wiring res. were empty and alarm went off when I turned the switch on. Just trying to figure this out Weekend coming up on us.
imagecat is offline
Old 07-02-2009 | 07:22 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Might be in guardian mode
John jr
Fenderjack is offline
Old 07-02-2009 | 09:13 PM
True, I had my alarm wires disconnected [still actually trying to sort them out!] and the alarm didn't go off, have you put a scan tool on it?, any codes?
Hope you get it sorted it, there are a lot of guys on here that have forgotten more than I will ever know, so, lets hope you get some input
Michael
Old 07-02-2009 | 09:54 PM
If in gaurdian mode wouldn't alarms go off?
imagecat is offline
Old 07-05-2009 | 09:18 PM
Got it It was the lift pumps were bad. Thanks for everybodies input.
imagecat is offline
