Is Fram Racing Oil Filter OK For HP525EFI >
Old 07-02-2009 | 03:36 PM
Default Is Fram Racing Oil Filter OK For HP525EFI
I just repowered to the 525. I bought a Fram HP4 filter and Valvoline "max life" synthetic blend 20w-50 oil. Will I be OK? Motor had a Wix filter when I got it but I couldn't find one of those. TIA.
thirdchildhood is offline
Old 07-02-2009 | 03:55 PM
Should be fine.
picklenjim is offline
Old 07-02-2009 | 05:07 PM
This should help you make a more informed decision.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Racerngr1 is offline
Old 07-02-2009 | 07:27 PM
Elite Marine's Avatar
Great post. Fram are terrible. Save yourself headaches and your engines, get something else. Napa filters are made by Wix. Find them or order them online.
Elite Marine is offline
Old 07-02-2009 | 07:28 PM
Filters To Avoid
The following list of filters have known problems. You will see well-known names here and will probably be disappointed. This is because many of these brands have stopped making their own filters and buy from a common manufacturer.
Fram Extra Guard
Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circuilating through my system. The oil passge to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it.
Fram Double Guard
Another bad filter idea brought to you by your friends at Fram. The filter itself is a slightly improved design over the Fram Extra Guard, but still uses the same filter element. It has a silicone anti-drainback valve, a quality pressure releif valve, and enough inlet holes for good flow. The big problem is that they are trying to cash in on the Slick 50 craze. They impregnate the filter element with bits of Teflon like that found in Slick 50. As with Slick 50, Teflon is a solid and does not belong in an engine. It cannot get into the parts of the engine that oil can and therefore does nothing. Also, as the filter gets dirty, it ends up filtering the Teflon right out. Dupont (the manufacturer of Teflon) does not recommend Teflon for use in internal combustion engines. Please do not waste your money on this filter.
Penzoil
This filter is a Fram! It is the exact same design as the Fram Extra Guard filter and it is junk. On the up side, it costs $1 less than the Fram version.
Quaker State
This is another Fram Extra Guard that I have seen at K-mart. It used to be a Purolator, but Quaker State is now owned/controlled by Penzoil...
Old 07-02-2009 | 07:30 PM
Fenderjack's Avatar
Pirate of the Chesapeake
I would not use a fram... Ac delco for me
John
Fenderjack is offline
Old 07-02-2009 | 07:39 PM
offthefront's Avatar
WIX 51060R Great Filters ....no bypass though so change em often ......m
offthefront is offline
Old 07-02-2009 | 08:12 PM
Thanks guys. I put the Fram on but haven't run the engine yet. I'll find the Wix and lose the Fram. Frequent oil changes will be done. This wasn't a cheap re-power!
Old 07-02-2009 | 09:56 PM
This was a very interesting and informative study.The only problem is it was done 10 years ago.A lot of things may have changed since then for better and worst. It would be interesting to see the same test done now.
Old 07-02-2009 | 10:03 PM
Dock Holiday's Avatar
Charter Member #34
I used the Fram HP4 for six years with excellent results on 500 EFI's.
Dock Holiday is offline
