525 EFI Max Water Pressure >
Old 07-04-2009 | 07:50 AM
Elite Marine's Avatar
Default 525 EFI Max Water Pressure
Anyone know what the max water pressure on the raw water side of a 525 cooling system is?
I would think it wouldnt matter as the water only goes through the exchanger and never touches seals/gaskets etc..
My current set up uses relief valves, but I was just wondering if they are really necessary.
Elite Marine is offline
Old 07-04-2009 | 08:37 AM
Rage's Avatar
Mercury spec on the sea water pressure for a closed cooling496 is 30-50 psi (5100rpm).
Rage is offline
Old 07-05-2009 | 09:05 PM
Thank you. Then it was smart of Mr. Zastrow to install reliefs on my 525's!! He sure doesnt look that smart!
Old 07-06-2009 | 12:44 PM
Brad Zastrow's Avatar
Glad to be of service smart azz.
Brad Zastrow is offline
Old 07-06-2009 | 09:06 PM
Kirk, What were you getting for pressure at WOT before you installed the reliefs. I'm off the gauge at about 40psi but I've heard that Mercury Racing says that's not a problem. Did I hear wrong? Steve
509 SC is offline
