What are the best quick disconnect fender hangers?
I hang 2 fenders from the rail on the side of my cockpit, one from a fender cleat I put on the bow. I use a quick disconnect to clip the fender on and off the rail, a fender grip to adjust. The cheap disconnects I got let go if too much force is applied. I dropped a fender leaving the launch today, had to go back and tie up again, lots of fun on a windy day by myself. I want to find a better quick disconnect set up, any suggestions?
This is what I have now:
[img][/img]
[img][/img]
Easiest way is to install some quick pin fender cleats. Mushroom Cleats will work fine as well. I have mine set up with loops to go on the regular cleats and some with regular lines that I can adjust height easier.
[QUOTE=GO4BROKE;2908230]I hang 2 fenders from the rail on the side of my cockpit, one from a fender cleat I put on the bow. I use a quick disconnect to clip the fender on and off the rail, a fender grip to adjust. The cheap disconnects I got let go if too much force is applied. I dropped a fender leaving the launch today, had to go back and tie up again, lots of fun on a windy day by myself. I want to find a better quick disconnect set up, any suggestions?]
You've got mail...
You've got mail...
