496 stroker built-ignition questions
Hi i need your help i'm having a 496 stroker built for my boat
and i don't know what ignition to put on the motor. my motor will have around 600 hp and it's a 94 454 mercruiser gen 6. I need everything coil,distributer ect.....thanks
If you need to custom taylor your advance curve to clean up the idle because of the cam, a mallory unilite is just the ticket and they work well, if not and you want a simple setup that works a aftermarket HEI is hard to beat at the rpm we run, down side is neither have rev limiter....Rob
It a Gen 6 engine, I don't think that has the Thunderbolt IV.
I would stay with the stock ignition also.
I have built a few 496's and it worked great for me.
I have always wanted to look into those, they look SWEET.
Do you know how much the advance curve is? Or do you just set it at total advance and let the base fall where it falls.
