gauges needed for pro-charger set-up ? >
Old 03-31-2002 | 10:52 PM
26sonic's Avatar
Default gauges needed for pro-charger set-up ?
can anyone tell me what gauges preferably gaffrig i'm going to need for my pro-charger set up ? do i need a boost gauge and fuel pressure? and what should the range read on these if i run 5lbs of boost ?
26sonic is offline
Old 04-01-2002 | 08:05 AM
Goodfella's Avatar
GOT MERC?
Cool
I guess you have a problem reading your own threads. Didn't we just discuss this issue in detail on a previous Pro Charger Thread?
Goodfella is offline
Old 04-01-2002 | 08:21 AM
Tell you what I have on my Whipple:
Boost gauge
Fuel pressure
Water Pressure for motor and intercooler
Thats what I have anyway.....
29scarab is offline
Old 04-01-2002 | 09:46 AM
Goodfella, if your not going to answer the question then don't reply. Obviously 26Sonic is trying to get as much info as he can.
The minimum you need is boost and fuel pressure. I have Gaffrig(livorsi) red line warning series. The warning series have a red light in the middle of the guage that lights up when there is a problem. The fuel pressure you need should range from 0-15 psi. Your running pressure will probably be between 8-13 psi. This guage can be either mechanical or electric sender. Mechanical is best but you will have to run a fuel line up to the dash. Boost guage should be between 0-15 lbs and definately mechanical. Other guages are a + to have but not needed.
Pure Energy is offline
Old 04-01-2002 | 10:14 AM
Kokopelli's Avatar
Ken,
Are you sure on those fuel pressure numbers - Procharger sets their systems up to run with over 40 lbs fuel pressure under boost, occaisionally over 50. I use a 0-60 fuel pressure gauge with my whippled motor.
Kokopelli is offline
Old 04-01-2002 | 10:26 AM
Official OSO boat whore
Perhaps a oil temp gauge would be in order.
Cord is offline
Old 04-01-2002 | 11:41 AM
Kokopelli,
That is what mine are set at. At idle I am at 8 and WOT 13+, 5-6 lbs of boost
Old 04-01-2002 | 12:38 PM
blown formula's Avatar
The differences in fuel pressures stated here can be attributed to carb vs efi systems. The efi runs at higher pressures. The carb version is around 7# at idle +1# of pressure for each # of boost (boost referenced 4-port regulator as provided by Procharger. The regulator boost port MUST be plumbed from the airbox nipple & not the intake manifold. So if you are running 5# of boost your max pressure will be 12-13# unlike efi which will be higher.
Gauges- boost gauge & fuel pressure minimum.
water pressure optional- adequate flow can be seen thru the tell-tale dump.
blown formula is offline
Old 04-01-2002 | 05:47 PM
26sonic's Avatar
thanks ken, just trying to get as much info as possible before starting this project.
26sonic is offline
Old 04-02-2002 | 04:46 PM
Goodfella's Avatar
GOT MERC?
Cool Pro Charger System Thread
Hey Ken,
The reason why I posted that comment is that 26sonic had the info already on a previous thread that he started. Named Pro Charger System. I guess he just likes to play with his keyboard
