502 mag intake and stuff >
Old 07-18-2009 | 10:26 AM
Default 502 mag intake and stuff
have upper and lower intake from a 97 502 mag efi motor. just intake no sensors or t-body. mint condition with nice gasket mating surfaces. no corrosion. $350 2 sets of EMI thunder risers for BBC, black and in mint condition also $150per set. swim platform off of a 1990 272 formula. has silent thunder exhaust and is complete with mounting hardware and exhaust tips, all white including rubrail $500 978 490 5281
prostockcat is offline
Old 07-20-2009 | 07:27 PM
How much for the swim platform?And is it wood?
beachcraft25 is offline
Old 07-20-2009 | 07:35 PM
its all fiberglass check out a formula in the classifieds 88-90 is a range of years. exhaust goes right through it (silent thunder) has exhaust tips and set up for dual motors even has gasket and mounting hardware. its all white $500
Old 07-20-2009 | 08:28 PM
will the risers fit stock 502 Merc manifolds? if so I am interested
paston1 is offline
Old 07-20-2009 | 08:43 PM
do you know if the intake is the same as a 94 454 mag efi? I have a friend that may be interested.
Pete280 is offline
Old 07-20-2009 | 09:21 PM
Do you know the EMI part number on the risers and do they have a "bung" for a sensor? Can you post a picture of them?
bigredbaja is offline
Old 07-21-2009 | 07:20 PM
risers only fit EMI THUNDER/REVOLUTION MARINE manifolds
the intake is the same as the 1994 as long as it is a mag motor
they do have a bung that i plugged. but it is there for a A/F ratio sensor emi-110
