380 K plane plates >
380 K plane plates
380 K plane plates
Old 07-19-2009 | 08:55 PM
Default 380 K plane plates
Looking for some 380 K plane plates. I got some brand new 280 plates that I could trade also. Looking for just the bottom plates not the whole trim tab. Thanks.
jdub is offline
Old 07-19-2009 | 09:34 PM
try craigs list and ebay
we have a guy at the marine that swears that he has been scoring big on ebay.....$800.00 for a pair of 380 in great shape?
give it a try
MACTIME is offline
Old 07-20-2009 | 06:25 AM
That's the first places I tried. I didn't find any. If you get a chance ask the guy if he can get another set.
John
jdub is offline
Old 07-20-2009 | 07:22 AM
RMPRam's Avatar
Default 380 tabs
I have a pair with the transom plates, and the trim cylinders (not pictured). $960+ shipping for everything, plus shipping
Gary
763-473-8963
Attached Thumbnails 380 K plane plates-380-tabs-001.jpg   380 K plane plates-380-tabs-002.jpg
RMPRam is offline
Old 07-20-2009 | 04:44 PM
Those won't work for me. I have the newer style with the bushing in the plate and ram. Thanks though. Put them in the swap section...you'll have them sold in no time.
jdub is offline
Old 07-20-2009 | 04:52 PM
They will work just fine,,,they are the same !!!!!!!!!!
the only diffrents is a 380 S and a 380 C ( the pin is bigger on the S ) if u have 380 C plates ,,,just drill out the pin hole.
The other diffrents is they are a tat stronger in the casting on the ribs for racing aplication.
THATS IT !!
DareDevil is offline
Old 07-20-2009 | 05:11 PM
I see what your saying but the new plates now use bushings in the rams and plates. I'm wondering if I can just drill the plate and do without the bushing in the plate. But I will still need the bushing in the ram to center the pin. I'll have to go look at my tabs tomorrow.
jdub is offline
Old 07-20-2009 | 06:25 PM
RMPRam's Avatar
There is a "bushing" in the ram, on the "rod" end. The pin that mounts the ram to the transom plate is 1/2" in dia. and 4 7/8" long. They use the same ss pin in the rod end of the ram, with a 3/4" hole bushed to 1/2". The holes in the bottom plate as well as the transom plate are both 1/2"
Hope this helps.
RMPRam is offline
Old 07-23-2009 | 07:33 AM
RMPRam's Avatar
Still have them, if anyone is interested.
Gary
763-473-8963
RMPRam is offline
Old 07-23-2009 | 10:57 AM
Just a heads up,but unless your engines are staggered,you may have to cut off a small area where they will hit the drives in a full turn position. I believe a stencil comes with them. I put 380's on the Slingshot about five years ago. Got a great deal from Diamond Performance who cut them and repainted them. Still, one of them would still just bump one of my #5's with the wheel at full lock. With a high 'x' dimension they really helped getting on plane with a full load.
Lmarth is offline
