Shifter Cable
Old 07-20-2009 | 05:12 PM
aviatorg3's Avatar
Default Shifter Cable
Need to replace my shifter cable on my 39' OE. Spoke to Ross and said it is a 33C cable but couldn't remember exact length. Does anyone know the length of the shifter cable for a 39 OE? Don't have the time to pull old one out and measure, want to get order placed ahead of time if possible. Thanks
aviatorg3 is offline
Old 07-21-2009 | 09:55 PM
MarkSmith's Avatar
Good luck with that one. I goes into a large pvc tube under the deck. Should not be too bad to pull through.
MarkSmith is offline
Old 07-22-2009 | 09:02 PM
bws's Avatar
bws
I changed mine out last season, wasn't that bad. The port side cable was 19', the starboard side was a little shorter (6" or 12"). My shifters are in the pod on the dash, not in the three man bolster. Hope this helps.
Brian
bws is offline
Old 08-03-2009 | 06:49 PM
If you look at either end of the cable there will be numbers in inches about two feet down the cable.
tizbad4 is offline
Old 08-03-2009 | 08:18 PM
Funny thing about my boat is.. I got Residential Down spouts running along the gunnels to get wire from the engine room to the front.. I about fell over laughing when i had it apart.. Down spouts... Not even pipe.. Times must have been tight when the built my boat!! LMAO
mmareno is offline
