Sonic 26 Prowler Low Compression >
Old 07-20-2009 | 09:24 PM
Default Sonic 26 Prowler Low Compression
My buddy went to buy a mint 99' Sonic 26 with 502mpi and trailer for 25,700 on Sunday. We did a compression test and one cylinder was half of the others. Do you think this is in the valves...head job? Or is it rings? Is the boat still a good deal and the owner did say he'd consider a lower offer to leave room to fix it. The boat did porpoise alot and he didnt like that but everything I've been reading looks like its a great boat. Thanks for all the input
brian18330 is offline
Old 07-20-2009 | 11:07 PM
Seriously, factor in the cost of a complete rebuild, then add about another 25%. That's for all the crap ya find after you pull the motor apart. There are a ton of great boats out there for reasonable prices. Don't buy a problem unless it's a GREAT deal.
Darrell.
DMOORE is offline
Old 07-21-2009 | 08:39 AM
Old 07-21-2009 | 09:17 AM
I'd have to side with Darrell on the "consider a full rebuild" cost. The motor is 10 years old, there is no need to fix only one cylinder on a motor that has that many hours.
The porpoising could have been from a lack of power out of that cylinder though!!
Knock the cost of a full "stock" rebuild off the price and you've got yourself a deal.
niceguy is offline
Old 07-21-2009 | 10:35 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I've put a few posts up about Sonics and porpoising. If you do a search, you will come up with some info. It has to do with the notched transom, and the boat running out of hull once it gets up on plane. It's only a pitfall in smooth water, and you can dial it out once you know the boat.
Sydwayz is offline
Old 07-25-2009 | 08:23 AM
did your friend end up buying the sonic?
cjcs is offline
Old 07-25-2009 | 06:07 PM
No he passed....really didnt like the way it rode and then the low compression was the clincher. I thought it was a good deal at 25k. He's still looking................
