BBLADES, what do I need ?
I have a 2000, Fountain, 27' 650hp, 1.5 bravo, lh rotation.
What prop do I need.
You labbed a 24p Bravo 1 for me when I was running stock 502 mag mpi engine and I really liked the way the Bravo 1 performed. I am getting ready to drop a 650hp engine in and I am going to need a good prop and value your advice......
Thanks for the question and sorry for the delay.
150 HP additions will dictate going up about 2 inches in pitch. We can test a 26 stock if you would like. We can also match the old recipe with the new one.
On the Hammer, Labbed Mirage Plus propellers are hard to beat when it comes to speed.
Brett
Brett
[email protected]
[email protected]
BBlades. I am needing help on correct pitch for BIII's on twin 496magHO's (X drives). Boat was used on higher elevation around 6000ft vs my location at around 630ft. Do I need to change the factory setting on current set up with this in mind? Not sure of current pitch, but will be checking.
Boat is a Cobalt 282. 9.6' beam. Around 6800lbs dry??? Thanks.
Check your PM.
B
B
[email protected]
[email protected]
