XR Parts Needed
Old 07-24-2009 | 01:04 PM
Elite Marine's Avatar
Default XR Parts Needed
Have a couple uppers and lowers that need some parts. Probabaly have three complete drives once I get some of these:
New Style Upper Seal/retainer
Vertical Shaft
Shaft Cam
Upper bearing assembly
Upper Gear set (1.50)
Anyone have any of these? Please send me pictures and prices to: [email protected]
Thanks!!
Kirk
Elite Marine is offline
Old 07-27-2009 | 08:53 PM
Bueller?
Old 07-28-2009 | 09:07 PM
t500hps's Avatar
21 and 42 footers
I have a XR that came apart at idle......brass ring on one gear broke off and pushed the spanner nut out the front cracking the case. The gears appear virtually unhurt as does everything else in the drive. I'm looking for an XR upper case to re-build this as a spare, interested in letting a housing go? I have everything else to put a drive together.
t500hps is online now
Old 07-29-2009 | 08:19 PM
Sold an upper case the other day...sorry.
Old 07-30-2009 | 07:19 AM
Mindi
Hello Kirk we have all those parts in stock at Doller offshore also when you say the vertical shaft do you the upper dirve shaft or the vertical shaft in the lower call us at 954-237-0332 Julio
Doller Offshore is offline
Old 08-08-2009 | 09:33 AM
Vertical in lower.
Will call this week. A few people have emailed me too.
Thanks.
Still looking.
Old 08-13-2009 | 03:03 PM
baja36ft's Avatar
Vertical Shaft
Shaft Cam
Thanks!!
Kirk
hey kirk i have a xr lower dwp it has a small crack in the housing but did not leak all the parts are in good shape 500.00 if you want it.....
baja36ft is offline
