Intake gsket on a 454 >
Old 07-26-2009 | 11:32 AM
Default Intake gsket on a 454
After the boat warms up to operating temperature, it starts to cut out at about 3500 RPM. Could it be vapor locking? Does the small square intake port on the gakets need to be blocked off? Could that be heating up the inake too much? It's a new engine, 465 HP with all new electronics. It runs great while still cold.
powerquest rick is offline
Old 07-26-2009 | 08:07 PM
I would try another distributor / coil. See you you can borrow one before you spend the money though.
getrdunn is offline
Old 07-27-2009 | 01:40 PM
Brand new distributor, msd box, coil, everything. Runs awesome til she warms up. I'm thinking that since my engine is a non EGR engine, that I need to block off the EGR ports through the intake. I think it was set up that way before but the new gasket set didn't have the block of plates. Would this cause my problem? Could the intake be seeing too much heat from the exhaust gases going through the EGR port? Maybe it's flashing the fuel off before it get into the cylinders?
