in need of a wiring diagram >
Old 07-26-2009 | 04:44 PM
Default in need of a wiring diagram
Looks like Im picking up that Baja tomorrow
First thing I want to do is re wire the boat
it has all the original wiring from 1987 in it and a lot of the gauges done work, plus I want to add some stuff like electric fuel pump, ignition box and coil and some other stuff I have laying around the garage left over from some of my race cars,
Does anyone have a generic wiring diagram I would use to referance
boat has a single 454 Mag motor and Im going to be switching over to a Holley carb that I have as well, and probably a dual plane air gap intake that I have as well also
also what type of wiring and terminals would you recommend using and does anyone have a good source to locate them at a good price if you do would you mind sharing
thanks for any help you can lend
cbellamore is offline
Old 07-26-2009 | 06:42 PM
I know this is not what you are looking for, But it is a start. This is just a standard Boat Wiring color Codes list, Just in case you are in need of it while trying to fix your boats wiring system. Good luck with it.
Blk -Grounds-General
Blk/Brn -Pump Grounds
Blk/Red -Voltmeter Grounds
Blk/Org -Isolated Accessory Grounds
Blk/Yel -ignition stop
Blk/Grn -Water Level Sender Ground
Blk/Blu -Lighting Grounds
Blk/Gry -Nav Light Grounds
Blk/Wht -Battery Parallel Solenoid
Brown -Pumps-General, Bilge or Sump (Manually Switched)(Also alternator starter to Ign.)
Brn/Red -Pumps, Bilge or Sump
Brn/Org -Power feed to Auto Bilge Switches-Pumps, Fuel/Oil Tranfer or Priming
Brn/Yel -Baitwell or Aerator
Brn/Grn -Fresh Water Pump/Water Maker
Brn/Blu -Head Pump
Brn/Vio -Washdown Pump
Brn/Wht -trim pos sender
Red - Battery Feeds Unprotected
Red/Vio -Misc. Accy. Main Feed Protected (fused) from batt to trim panel.
Pink -Fuel Sender
Org/Blk -Audio System Feed
Org/Brn -Electric Head-Sanitation System
Org/Red -Wiper Port
Orange -Accessories common feed- Dist Panel to Acc switch-Anode Electrode-Mercathode
Org/Yel -Diesel Pre-heat
Org/Grn -Wiper Stbd
Org/Blu -Communications Equipment
Org/Vio -Navigation Equipment
Org/Wht -Wiper Center
Yel/Blk -Choke - Neutral saftey trans mounted
Yel/Red -Start Solenoid(starting circut), Neutral Safety
Yel/Org -Powered Ventilation, Fans
Yellow -Bilge Blowers -(also alternator DC output)
Yel/Wht -Rudder Angle Sender
Grn/Red -Stop Solenoid/Kill Switch
Grn/Yel -AC Grounding
Green -Bonding
Grn/Wht -Engine Trim in and or tilt down
Grn/Org -Engine Independent Trim down
Blu/Blk -Cabin Lights
Blu/Brn -Oil Temp Send
Blu/Red -Cabin or Cockpit Lights Port
Blu/Org -Engine Independent Tilt Up
Blu/Yel -Lighting Circuits to Remote Send
Blu/Grn -Cabin or Cockpit Lights Stbd
Blu -Instrument & General Lighting
Blu/Vio -Courtesy, Boarding Lighting
Blu/Wht -Engine Trim Outand/or Tilt Up
Light Blue -Oil Pressure
Vio/Red -Eng. or Generator B+ from Breaker
Vio/Yel -I/O Trim Up (ballast bypass)
Vio/Grn -I/O Trim Down
Vio -12v Ignition-Generator or Engine
Vio/Wht -Trim "Trailer" switch
Gry/Blk -Mast Light
Gry/Red -Spotlight Remote
Gry/Org -Docking Lights
Gry/Grn -Strobe or Beacon
Gry/Blu -Spreader/Flood Lights
Gry/Vio -Windlass/Winch
Gray -Navigation (running) Lights, Tach. Send
Gry/Wht -Anchor Light
Wht/Brn -Temp. Alarm or Indicator
Wht/Red -Fuel Alarm or Indicator -((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Org -Fire Alarm or Indicator
Wht/Yel -Air Flow Alarm or Indicator
Wht/Grn -Water Press/Flow Alarm or Indicator - ((Ignition module to Dist.)Mercury Thunderbolt Ignition)
Wht/Blu -Oil Press Alarm or Indicator
Wht/Vio -Voltage Alarm or Indicator
White -General Alarm Usage, Yamaha Kill Switch
Tan - Water Temp sender
Tan/Blu -Warning system sense wire (Audio warning)
Pink -Fuel sender
Boat Tech is offline
Old 07-26-2009 | 06:59 PM
thanks
thats helps
Im gonna be doing everything over from scratch including switch panels, gauges, etc.
I couldnt really find anything with an actual picture from doing a search
if anyone has a link to an actual picture even if its homemade that would help greatly
thanks
Old 07-26-2009 | 07:03 PM
Brn/Blu -Head Pump
Pink -Fuel Sender
Org/Red -Wiper Port
Org/Grn -Wiper Stbd
Green -Bonding
Gry/Blk -Mast Light
Pink -Fuel sender
DAMN,,,are u bored ??? LOL
Nice togh ,,i can use that too.
DareDevil is offline
Old 07-26-2009 | 09:31 PM
Yes I am bored, But not that bored, I found this new thing called copy and paste. LOL. I found that on a different fourm. Glad I could help out. Sad part is I know most of them with out looking them up.
Old 07-26-2009 | 09:37 PM
Originally Posted by cbellamore
thanks
thats helps
thanks
Try playing in here a little, open service manual # 16 you might get lucky.http://www.boatfix.com/merc/mainmenu.pdf
Old 07-27-2009 | 05:44 AM
Hope this helps.
Let me know if you need anything specific, I have all of them.
Regards,
John
Attached Thumbnails in need of a wiring diagram-454-502-tbiv-carb-wiring.jpg   in need of a wiring diagram-454-502-mpi-wiring.jpg   in need of a wiring diagram-wiring-harness.jpg
in need of a wiring diagram-main-harness-wiring-c.jpg   in need of a wiring diagram-dash-wiring-harness.jpg
Ghostrider is offline
