Need Help!!
Old 07-26-2009 | 06:57 PM
Default Need Help!!
I have a 496 Mag HO with a closed coolant system, with steam coming out of the port side (I believe, hard to tell with the swim platform). I pulled the riser off and found no water in the manifold, put it back together and the steam was worse. So I figure thats were it is leaking. On my way back across the lake it started missing. My question is, could it have gotten the plug or plugs wet enough to foul them? I pulled the plugs and the back two looked black. No water in the cylinder or the oil. Thanks for your time and help!!
05RINKER is offline
Old 07-26-2009 | 07:01 PM
Sounds to me like its running rich on the rear corner !!??
Maybe injectors or sensors ?
DareDevil is offline
Old 07-26-2009 | 10:40 PM
Wink
What year is your 496 and how many hours on the engine??
Best Regards,
Ray @ Raylar
Raylar is offline
Old 07-27-2009 | 10:39 AM
It has less than 4 hours, just rebuilt it, didn't change out the riser manifold gaskets. Is it possible that water got into the cylinder, and fouled the plug or plugs from the gaskets leaking?
05RINKER is offline
Old 07-28-2009 | 09:17 AM
Best Regards,
Ray @ Raylar
05RINKER is offline
