how to tell if I definately have a magnum motor
I just got a new to me Baja boat, its an 87 and the previous owner had paperwork that showed he had a new motor installed in 2005,
its supposed to be a 2001 Merc Magnum 454 motor,
I checked the casting number on the bellhousing and the numbers are
12550313
which state according to a search on here thats its a
454.......91-up...4-bolt, Gen.V crate motor, Gen. VI 4.25" bare block, fuel pump boss
there is also D050 cast in to the bellhousing as well,
what else should I check for
the carb flame arrestore says 454 merc magnum on it but I konw that can be from anything
just trying to verify exactly what I have because I would like to possibly upgrade to a bigger cam, new intake manifold and bigger carb very soon like in a few days if possible
thanks for any help
12550313
thanks for any help
12550313
thanks for any help
12550313
thanks for any help
you can pull a valve cover also and see what heads you have. sounds like it's a magnum with the forged internals, 7/16 rods. no real way to be certain with out doing a complete pull out and drop the pan. i doubt anyone would put a cast crank in a 4 bolt block. does it look like it has been apart? Look near the front and rear sealing area of the intake as well as bolt heads for signs of being apart before.
regardless pull a valve cover to see what heads you have and persue your upgrades. there are numerous threads pertaining to 454 upgrades or roids. if you need some help email me and i will help you.
john
[email protected]
john
[email protected]
i doubt anyone would put a cast crank in a 4 bolt block. l][email protected][/email]
And I have been around ages
Also the true 454 mags had Rectangular heads not the small ovals. That might be your best sign.
The 330 has a cast iron intake. Not sure about the Mag. Pull a valve cover and get the casing number. If you upgrade the cam don't forget the aftermarket exhaust. Be sure to get long risers to avoid reversion. Be sure you also upgrade the oiling system. These are things I did not do first and blew it up 3 times before getting it worked out.
The old 454 330 HP were two bolt mains. The Mark IV blocks with 4 bolt mains have two of the same size pipe fitting just above oil filter boss. If one is smaller that other its 2 bolt mains. If your intake runners almost touch the valve covers you have sqare ports heads (used on Mags and higher HP motors) If your intake runners are about 1/2" lower than you have oval port heads. Those are a couple of way the try to figure out what you got without taking anything apart. Hope it helps.
My 330HP 7.4L 1994 was a 4 bolt main. I have not heard of any 2 bolt main BBC marine blocks. Thats not to say they do not exist. What years were the 330's 2 bolt mains? The easiest way to tell is to get the numbers off the block and check mortec.com for the specs. Even with that info you can not be sure of cast or forged internals if it has been rebuilt.
john
