Trailer disconnected message
Old 07-28-2009 | 09:11 AM
Default Trailer disconnected message
Recently converted my MYCO to BrakeRite EOH. Everything on the trailer, lights, brakes works great but I keep getting the "Trailer Disconnected" warning from the integrated brake controller. (2005 F250 with factory brake controller). Have checked ground and even run an extra ground wire from the truck to the trailer. Also installed the Brakerite SD Converter P/N 4845900 (before I installed this, when I hit the brakes the reverse lights would come on).
Discussed with Brakerite but they were no help.
Any ideas???? Thanks
ciaoderhead is offline
Old 07-28-2009 | 02:28 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It sounds like you need to go over each of your trailer pinouts. I had to do this on mine. Your junction box inside the frame rail of the trailer is an easy place to make adjustments.
Sydwayz is offline
Old 07-28-2009 | 03:04 PM
Dock Holiday's Avatar
Charter Member #34
If memory serves me right the problem is with the factory built in controller in the truck. Seems that folks were having a lot of problems with it in both the Ford and the GM models.
Do yourself a favor and invest in a MaxBrake controller and you will be VERY happy. I did not have a built in unit and when with the P3 which was nice but switched over to the MaxBrake based on reports I had read and it is AWESOME.
It's very smooth and the truck and trailer stop as one.
Good luck
Dock Holiday is offline
Old 07-28-2009 | 09:12 PM
scottsumrall's Avatar
Ford factory brake controller will NOT work with the EOH brakes. You must install a new brake controller. I have an 08 f-450 and had the same problems. Also you will have to have the dealer reprogram the computer. Hope this helps.
scottsumrall is offline
Old 07-29-2009 | 02:25 PM
plumbers crack's Avatar
Default brakes
Same here, Put a $50 brake controller right next to the Ford One.
plumbers crack is offline
Old 07-30-2009 | 09:14 PM
2112's Avatar
WTF? my 2006 has worked beautifully for 4 years. Could it be your model year?
2112 is offline
Old 07-30-2009 | 10:15 PM
you will need a converter for this set up to work i bought mine from southwesttrailer.com. You can do a search on google for brakerite adapter first thing that comes up is the southwest site it worked on my f-450 and new trailer
galex0100 is offline
Old 08-01-2009 | 09:35 AM
My brakerite works perfectly with a 06 F-350 and a 08 F-450. Do not install an aftermarket controller. The Tow command ford is the best by far. It is intergrated into the computer to assist in braking and shifting. It still sounds like a ground issue. I have had the same issue and it was the grounding lug on the trailer frame. GREAT SYSTEM
fossil fuel is offline
Old 08-01-2009 | 05:23 PM
bowtie's Avatar
The Ford controller works good with some systems but not good with others. I ended up going to an aftermarket controller for my truck and it works good. The Ford one had a slight delay and you couldn't control it. Finally it just started running the pump whenever the ignition was turned on. It worked good with another trailer with 1 different brand Electric over Hydraulic unit. So it all depends on what system you have on your trailer. I was told there are some kits to improve Fords controller on certain systems, but none was available for mine.
bowtie is offline
Old 08-01-2009 | 09:55 PM
My 06 works just fine with EOH on My travel trailer and boat trailer. I will find out tomorrow if my new 09 does
Anchorman is offline
