Best prop for Stingray 230SX
I'm going to assume you're running a 375hp motor since there's only a couple of them out there with the 425hp engine.
A 23" Mirage is probably the best all around. A labbed 25" Laser II (with ventholes plugged) will be the fastest, but it will be a problem to plane out. I know some guys who had some luck with 21 Rev4 props. Hopefully your boat has trim tabs. Also, the 220 and 230 Stingrays were very bad about engine ventilation. A "cold air" mod will get some fresh air in there.
