Looking to add shorepower and AC, help me out >
Old 07-29-2009 | 07:47 AM
Default Looking to add shorepower and AC, help me out
I want to add shore power and air conditioning, but do not need a genny because I will only use it when hooked to the dock.....any suggestions??????
302Sport is offline
Old 07-29-2009 | 10:28 AM
monstaaa's Avatar
cable. service outlet, 10 gae triplex, breaker panel 110, ac unit, thru hull for supply, ball valve , thru hull for dump.
monstaaa is offline
Old 07-29-2009 | 11:36 AM
Panther's Avatar
Frank's Marine Service
I like the idea of installing a charger/inverter in these instances. The shorepower can/will run your AC and some recepticals. When you're away from the dock/shorepower you can run the inverter with the engine on to feed the AC and cool down the cabin for a little bit. With the engine off you probably can't run the AC and if you do the batteries wont last long but you can use the recepticals.
just my $.02
Panther is offline
Old 07-29-2009 | 11:41 AM
Panther's Avatar
When installing the breaker panel, be sure to get one that's made for shore power. Warning, they can be expensive $175-200+.
The breaker on the shore power panel cuts both +/- legs when you flip the switch and also has a light that comes on so you know if you are hooked up with reversed polarity.
Panther is offline
Old 07-29-2009 | 03:01 PM
aTX427's Avatar
Look at MarineAir or Mermaid - 5,000 BTU should suffice.
aTX427 is offline
Old 08-02-2009 | 06:31 PM
Just added shorepower to our boat don't forget about a galvanic isolator. It reduces chances of stray current (galvanic corrosion) & electrocution.
NEVERSATISFIED is offline
Old 10-10-2009 | 03:25 PM
We have a system that runs on 12 volts, but doesn't use a power inverter to run thanks to 12 volt compressors, they come in 4k btu and 6k btu. Then add your shore power charger! http://www.12voltac.com
cruise n comfort is offline
Old 10-10-2009 | 04:08 PM
Strip Poker 388's Avatar
Rob
I bet you could find some surplus marine place that has a 110 panel with all the wiring cheap. I have picks Of my factory panel front and back,electrical out lets,shore power plug,battery charger etc.if ya want the picks,holler,there on my home puter.I think I Even have a wiring diaragham of the panel from Hustler.
Rob
Attached Thumbnails Looking to add shorepower and AC, help me out-11-07-2-271.jpg
Strip Poker 388 is offline
