Got Me A New Boat!
Old 08-03-2009 | 10:59 PM
Default Got Me A New Boat!
Going tomorrow to florida , 18hr drive, to get my new to me boat!
1978 25' Martini
505 Supercharged Carb 40hrs since rebuilt
Thru Hull exhaust
Brand new Upholstery (used twice since new, Bolsters, back seat, sunpad, cabin) Yellow/ Purple stripes
Trim tabs
Bravo 1 Drive
New Paint
New Controls (purple)
New Steering wheel (purple)
Everything is basically new...
Galvanized Trailer
All for $12000... Good Deal?
I am going to put in a sound system over the winter...
Want Speed is offline
Old 08-03-2009 | 11:09 PM
Also I have asked this guy a bunch of questions...
but are there anymore that I should ask?
and when I get down there what should I look for when I am inspecting it as far as bad/good on hull, floor, motor, ect... Ill post up some pics of the boat that he sent me so y'all can see her! He is going to let me hear it run, but it will be too late to go out on it.
Old 08-03-2009 | 11:15 PM
and the tow rig...
Old 08-04-2009 | 12:37 AM
It has a Bravo 1 drive in the pics. Good thing because an Alpha wouldn't last 30 mins.
Griff is offline
Old 08-04-2009 | 12:45 AM
Your right DUHH... I was looking at another forum about an Alpha 1 right before I made that post... Thanks!
Old 08-04-2009 | 12:46 AM
Does he run it in the ocean? When was the last time a survey was done?
Did he say how fast? You may want to put hydraulic steering on it.
I wonder how much good that low-pro scoop is doing hidden behind the backrest...
I'd have the motor checked out by your mechanic. It looks like it's seen a lot of hours.
Nice truck!
Catmando is offline
Old 08-04-2009 | 01:22 AM
Pretty sure the scoop is there to fit the carb under the lid...
he said it runs 80's... said he had it up to 92mph but Idk if I believe that...
The season is almost over, so a couple 3-4 outings and the boat will be going to the mechanic for winterization so I will have him check everything out...
I thought the same thing about the engine, but then i figured if its in Miami **** rusts and discolors just by sitting outside... especially being out on the water.
I will probably ask for receipts and stuff like that.
Old 08-04-2009 | 04:52 AM
See that rust run under the transom assembly... take a small hammer with you and tap on the transom on the inside of the boat. Listen for soft spots. Ask him if the transom or stringers have ever been redone.
They are fun boats...handle the rough stuff good for their size.
jdub is offline
Old 08-04-2009 | 05:07 AM
get a survey, before you drive 18 hours....the little bit you spend will save you down the road. unless it's already a done deal....
ciaoderhead is offline
Old 08-04-2009 | 08:29 AM
I have a survey lined up for tomm morning at 7am to get it all checked out... I chose the Atlantic Marine group in Miami, Fl to do it. When i called they sounded extremely professional.
It is $525 for a full survey, compression and oil analysis on engine, and Oil analysis on the drive.
