240 Sport >
240 Sport
240 Sport
Old 08-06-2009 | 08:09 AM
RICHARD CUNY's Avatar
Default 240 Sport
I need some input my marina has replaced 3 alt this year removed the engine trying to find a leak with no luck they feel the water comes in the vents but i have been photoed in a few poker runs and i have never seen any sign of water. I would apptreciate any help .
Rich
WATCHUS
RICHARD CUNY is offline
Old 08-06-2009 | 08:48 AM
c_deezy's Avatar
Replaced the alternator why? Because of water intrusion? No way water is coming in the vents of a 240 while you are running unless you are taking serious waves over the bow. Take the hatch off and run it, then you can watch and see where the water is coming in from. Maybe there is a pinhole/split hose going to the port side exhaust riser that is spraying on the alternator.
How much water are you taking on?
c_deezy is offline
Old 08-07-2009 | 08:51 PM
Default 240 Water
Took a ride this eavning 1hour 4gallons of water the strainer was very wet I will get a friend to watch while under way i think it happens only when the water pick up is under much presure from speed. seemes to be mostly on the starboard side were the strainer and pump are.
RICH
THANKS FOR YOUR INPUT
WATCHUS
Old 08-10-2009 | 07:10 AM
Default Leak
Pressure tested the raw water line found two bolts gone on the hardin flange into pump with the oring hanging out and the bolt to bracket to the alt. missing I wonder what I pay my marina for just seems if you need somthing done rite do it yourself. last problem was a bad alt. and they left the lower bracket off and the belt loosened up and I overheated.
Rich
WATCHUS
Old 08-10-2009 | 08:49 AM
bajarick's Avatar
It seems you cant even pay to
have reairs done rite with out
refixing it yourself. Ive learned
to only pay the bill by credit card
so that you have some resouse if
the repair is not done rite.
Rick
bajarick is offline
Old 08-10-2009 | 11:07 AM
c_deezy's Avatar
Rick
That seems to be the case, more often than not. It's in your best interest to learn how to do things yourself, especially on an older boat or it will nickel and dime you to death. It also familiarizes you with your machine so that if you do have something go wrong on the water, if you have the tools and spare parts you can fix it yourself. Personally I don't understand how the average guy can afford to have routine maintenance done at marina shop rates.
c_deezy is offline
Old 08-11-2009 | 07:33 AM
Default Bolts
I ordered heli coils to repair my pump they should be in today. I cleaned the motor this morning with Zep purple took the anadize coating off made a mess on my Harden surpentine front assembley my blue fittings on fule lines,and my blue top on my teague strainer.
Rich
WATCHUS
Old 08-12-2009 | 03:46 PM
My First Dry Ride Today In 2 Years 1 Hour Ride No Water In Bildge What A Great Feeling
Rich
WATCHUS
