Go Back  Offshoreonly.com > Owners Forum > Advantage
Prop for 22 Citation >
Old 08-06-2009 | 11:44 AM
Default Prop for 22 Citation
Hello,
I have a 93 22' Citation and I am currently running a 23P Bravo 1 prop (3 blade). The motor will turn out 5200 rpm at WOT. I know better than to run it up that high but has any one had any experience with repropping their 22' Citation? Any suggestions on a prop make or size will be appreciated.
Thanks in advance.
Rich
produck1 is offline
Old 09-23-2009 | 10:40 PM
LakeRacer's Avatar
Charter Member #9/ Moderator
Default Took a while
but you finally get an opinion for your question.
5200 rpm is the right range depending on motor. If you want to drop the rpms I would suggest a 4 blade bravo one in 24pitch. It should drop your rpms 200-300, you might get better holeshot, won't blow out as easily and get really lucky with a couple more mph.
Art
LakeRacer is offline
