Spark Plug Wires and Distributor - When to Replace? >
Old 04-02-2002 | 05:13 PM
Default Spark Plug Wires and Distributor - When to Replace?
How do you know when to replace your spark plug wires? How about the distributor cap?
My wires are probably 10 years old. The cap is probably 5 years old. Everything runs great and looks to be in good condition (no cracking on the wires).
Any hints?
Thanks!
stevel is offline
Old 04-02-2002 | 07:23 PM
After 5 years, I'd probably get a new dist cap as preventive maintance. As far as the plug wires, if they look good, they're probably ok, but 10 years is pretty old. They could have some small cracks that you can't see.
Griff is offline
Old 04-03-2002 | 08:34 AM
formula31's Avatar
Wow, I change mine every year. Heres a good way to check them, well I dont know if its a good way but it works. At night, in a very dark place with as little background light as possible, start the engine with the hatch up and look for lightning. If you really want to be sure, spray some water from an old windex bottle around the cap and wires and watch for lightning. I would think 2 years max on the cap and 3 on the wires. But thats up here in the great white north.
formula31 is offline
Old 04-03-2002 | 08:54 AM
Crazyhorse's Avatar
Yeah, see, I prefer the hands-on method of checking the wires. I call Dyno to come over and put his hands on the top of the distributor cap while the engine's running. If he makes any wierd sudden jerking motions and vulgarities spew from his mouth I have a clue that one or more wires may be leaking. Seriously, I think you've gotten your money's-worth out of those wires. I encourage people to replace the cap every year and the wires every two years.
Crazyhorse is offline
Old 04-03-2002 | 08:59 AM
formula31's Avatar
Hi CH How ya feeling? I did what you suggested once with my Crane Hi-6 and it almost stopped my heart.
Old 04-03-2002 | 01:34 PM
cardshark 388
When you talk about changing the cap once a year and the wires every two years how many hours are you talking about? Once a year here in Michigan is different than once a year in Florida for example. Or does the amount of hours you put on your boat have no effect on when to change.
Cardshark
Old 04-03-2002 | 02:01 PM
how about ohm them out to the spec in the manual!!!
audacity is offline
Old 04-03-2002 | 05:16 PM
I have looked at night but I didn't see any sparks leaking. Crazyhorse - thanks for the suggestion but I think I will pass. I am looking for something a little more scientific.
What should a good set of cables read across an Ohm meter?
I would personally guess that some of you guys that are replacing these components every year or two are probably doing so needlessly. These components last for years under automotive conditions that are much more extreme than a marine engine compartment. (Hot headers, water, snow etc) I also agree that a spare cap and rotor never hurts.
Thanks for your imput!
Steve
stevel is offline
GK
4
06-26-2008 07:45 AM
rangerrick63
06-10-2007 08:15 PM
gripit
7
04-01-2007 09:57 PM
puder
2
08-31-2002 11:25 PM
stevel
04-03-2002 05:33 PM
