Surge -> EOH Conversion
Old 08-08-2009 | 11:21 PM
Default Surge -> EOH Conversion
As I plan to do some distance towing, hilly terrain, looking into converting triaxle (Pacific Boat Trailer G27TR16-14) from surge disk to EOH. This forum has been a great resource. Leaning toward the BrakeRite EOH with MaxBrake controller. Has anyone done this conversion as DIY? Suggestions?
70runner is offline
Old 08-09-2009 | 06:38 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Your biggest decision is what to do with the coupler. Some folks go simple and just weld or bold the surge coupler solid. That just doesn't seem right to me.
Check out http://www.championtrailers.com/ or http://www.redneck-trailer.com/ or any of the other trailer parts houses on the web to find a solid coupler that will bold on in place of what you have. It's never a bad idea to go with a new coupler. I have a 2005 Myco and bought a whole new coupler from them which installed in about 5 minutes and my setup is tighter than it ever was.
Make sure you mount the whole EoH setup HIGH and FORWARD so as not to get wet; including the battery, (but keep in mind you want to be able to lower your tailgate on the truck). Make sure you mount the break-away switch in a non-precarious position, (i.e. NOT on bottom of trailer). Some trucks have empty fuse blocks from the factory waiting for you to install fuses to provide full power to the brake harness & trailer plug.
I have several posts on here and Serious0ffshore.c0m about MaxBrake. The system is awesome and quite simple to install; albeit it's a little finicky to get the plumbing right.
Sydwayz is offline
Old 08-09-2009 | 07:56 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I did the exact same thing last yr using the Brakerite and Maxbrake controller on my Eagle disc brake trailer. Best thig ever! I gutted the coupler and had it welded solid.
US1 Fountain is offline
Old 08-09-2009 | 07:58 AM
Ginger or Mary Ann?
http://www.offshoreonly.com/forums/t...iler-redo.html
Old 08-09-2009 | 01:25 PM
Originally Posted by US1 Fountain
Very nice! Heres a pic of my coupler (still sitting at the dealer, take delivery of Regal 2860 next week). They've offered to drop the trailer/boat at trailer manufacturer to convert (about $1K), but I believe after reading through your conversion I can do this!
Brian - thx for input, I'll check those sites. I do have about 20yrs of welding experience, but a coupler replacement might be more prudent for my 12K load.
I assume the master cylinder is inside the coupler housing and the corresponding hydraulic line would be the one used for connecting to the BrakeRite?
70runner is offline
Old 08-09-2009 | 07:16 PM
Ginger or Mary Ann?
It's really an easy job to convert. Looks like yours is galvanized. Not sure I'd mess with welding it, plus the bolt on solid coupler would look cleaner by removing the all of the surge coupler unit above the frame.
Yes, the hyd line going to your M/C will now go to the BrakeRite power unit.
Last edited by US1 Fountain; 08-09-2009 at 10:13 PM. Reason: Pic didn't show up earlier
Old 08-09-2009 | 07:44 PM
c_deezy's Avatar
One reason NOT to weld your existing surge coupler is you can sell it and try to re-coup a little bit of your expenses.
c_deezy is offline
Old 08-09-2009 | 08:13 PM
weld it in the compressed position. i have done this conversion lots of times.
fountainemp is offline
Old 08-10-2009 | 02:38 PM
I did this to a 07 myco tri axle disk had no problem only bleed the EOH unit because there was no air at the brakes. As far as the coupler just pulled it all the way out and drilled 1/2" hole and put a bolt in it. The brakes work great. Now you can back up the trailer again.
mudslide is offline
