prop help for a 22 Scarab 350 mag.
Well, just purchased my first scarab and need some opionions on a new prop. I'm not sure what's on it right now, "except it's a p.o.s."... Does a 4 blade s.s. and about a 21 pitch sound about right????
My buddy has a 1987 Scarab 1 which is a 22ft with a 350 mag in it and alpha 1. He is running a 21P Mirage plus which is turing the motor to about 4700rpms and is in the 54-55mph range with gps. The only thing I noticed was it takes it a little bit to get on plan but after that it handles and ride's great.
Erik
Erik
Try a revolution 4 21p and 23p. Should work ok. I would guess that the bravo might be a bit large. See if a Mirage plus will work. Usually the drive on a boat like yours, is placed somewhat deep. If so, the 4 blade will rob you of speed. Try a good 3 blade like the Mirage Plus, it's a great prop.
Sounds like the Mirage Plus is the verdict... Want to be able to get out of the hole as quickly as possible, but would like a top end of 60'ish, "if I can have my cake and eat it too..."
Thanks guy's...
Thanks guy's...
Erik
Erik
If you would like to test some 3 blade propellers as well a the Revolution 4, call us and we can arrange it.
Brett
Brett
[email protected]
[email protected]
