Saltwater damage prevention >
Old 08-17-2009 | 02:45 PM
Default Saltwater damage prevention
Here is the ever asked ?? What is the best method to clean up and prevent salt water residue in & outside of motors & bilge area??? Although this seems like a no brainer I thought I would throw it out there for any new thoughts and ideas!!!
Please send any & all to make a Florida boater sleep after running in salt.
Thanksp:
Belsie is offline
Old 08-17-2009 | 03:03 PM
KEPP's Avatar
Only the Best Will Do!
Thanksp:
This is the best product I have ever found http://www.keitheickert.com/detail.aspx?ID=9151[/COLOR]
Best Regards
KEPP is offline
Old 08-17-2009 | 03:06 PM
seafordguy's Avatar
Agreed. I flush mine EVERY time with Salt-A-Way.
seafordguy is offline
Old 08-17-2009 | 03:08 PM
Salt A Way works great !!
offshoresteve is offline
Old 08-17-2009 | 03:18 PM
I use warm soap and water, then a salt-a-way flush/ rinse.
Darrell.
DMOORE is offline
Old 08-17-2009 | 06:51 PM
CRC the entire motor and all hardware before going in, in addition as stated above.
AO31 is offline
Old 01-06-2010 | 05:12 PM
What model of crc is best? I pulled my boat of of the water one time in miami and the guy at the marina gave me a spray bottle of something??? I sprayed it on my drives and it made them look wet. Then, when dried it looked normal until I rubbed it and it made my fingers dirty. It was awesome!! I need this stuff!!! Is this crc????? What type of CRC?????
krazy1 is offline
Old 01-06-2010 | 07:27 PM
Any general purpose (CRC power lube / used to be called 444) lubricant will do the trick. Spray entire motor,mounts, anything metal.
AO31 is offline
