Best Chemicals to use on your boat >
Old 08-20-2009 | 02:08 PM
rtaylor's Avatar
Default Best Chemicals to use on your boat
I have been told and have read that the following are the best 5 chemicals or mistures to have around. I forget what each one is good for. Does anybody know and would anybody care to agree or disagree? Of course, wax is probably #6 after these chemicals are used to clean.
Vinegar and Water
Degreaser
Acetone
Hull Cleaner
Toilet Bowl Cleaner
rtaylor is offline
Old 08-20-2009 | 02:36 PM
I use Vinegar and water to remove water spots and Sno Bowl toilet bowl cleaner to remove the yellow stains from the hull.
I have used the Sea bright hull cleaner but Sno Bowl does the same job and costs alot less.
And Yes, Wax is a must after using hull cleaner or Sno Bowl.
debcod2 is offline
Old 08-20-2009 | 03:01 PM
GLH's Avatar
GLH
Ketel One
GLH is offline
Old 08-20-2009 | 03:24 PM
LAriverratt's Avatar
Originally Posted by GLH
Ketel One
If you use to much that could leave a stain
LAriverratt is offline
Old 08-20-2009 | 03:54 PM
Best Chemicals to use on your boat ??
It's not my cup of tea but I know a few people that smoke a lot of pot on their boat. They seem to enjoy it.
salesmanship is offline
Old 08-20-2009 | 04:15 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Ky
Sydwayz is offline
Old 08-20-2009 | 05:05 PM
Vinegar and Water
Degreaser
Acetone
Hull Cleaner
Toilet Bowl Cleaner
To get off really stubborn hard water spots, I use a mixture of 2 cups of Simple Green and one cup of white vinegar.
hooky40 is offline
Old 08-20-2009 | 05:54 PM
scarabman's Avatar
Ketel One
Ketel One is swill. You need to try Double Cross! Check out the review in the latest issue of Playboy. (Really, I only read the liquor reviews)
scarabman is offline
Old 08-21-2009 | 07:59 AM
rtaylor's Avatar
Any suggestions on wax? Also, how important is it to compound? How is that done?
rtaylor is offline
Old 08-21-2009 | 08:30 AM
Best I have used so far is Collinite heavy duty past wax.
4mulafastech is offline
