help - lost top end >
help - lost top end
help - lost top end
Old 08-22-2009 | 06:50 PM
Default help - lost top end
Hello All,
I have an '04 25 outlaw with the 425hp. It has a 23P balanced prop and captains call exhuast. The boat has 180 fairly easy hours on her. Last summer it was doing 66-67mph on gps at 5200rpms. This summer I am getting about 62mph at 5000rpm's.
It idles fantastically at 700 and cruises at 3800 45mph dead on with 2 people 1/2 tank of gas.
So, what happened? I changed my water/fuel seperator and in-line fuel filter, which by the way I got screwed for $52.
I am not sure of the next step, the prop looks great and I am looking for advice. Oil is changed every 20 hours.
Cheers,
Scot
bluefox70 is offline
Old 08-22-2009 | 08:02 PM
Originally Posted by bluefox70
Hello All,
Cheers,
Scot
Change your plugs...
Was the temp and humidity the same? Heat will cause loss of speed
Irishtornado is offline
Old 08-22-2009 | 08:57 PM
you also may want to check the compression to be safe.
indywhsle is offline
Old 08-22-2009 | 09:27 PM
TEAMBAJA's Avatar
At the last dealer meeting every boat was about 4 to 5 mph slower in the Florida heat. Up here they ran fine.
TEAMBAJA is offline
Old 08-23-2009 | 07:55 AM
Interesting, I am in New Hampshire and our humidity over the last week has been horrendous and temps around 90.
These are platinum $$$ plugs, how often would you change them?
Cheers
Old 08-23-2009 | 08:51 AM
Cheers
If they are the original plugs I'd probably say your due...
Old 08-24-2009 | 11:44 AM
Motors vary wildly due to heat. My boat runs up to 8mph difference in 115 degrees versus 80 degrees.
relaxalot is offline
Old 08-24-2009 | 07:47 PM
My bet is the heat and water temp.
redbud35 is offline
Old 08-25-2009 | 11:47 AM
The boat has a closed system. So, its not water temp. Heat and a mixture of moisture makes sense, though.
I have done the in-line fuel filter and water seperator with no luck. I am going to do the plugs this weekend and will update all.
Relaxalot, be happy your boat or yourself runs at all at 115 degrees. I though you had to get to New Dehli, India to see those temps.
Old 08-25-2009 | 12:35 PM
It might have something to due with all this crappy gas we have been getting for awhile. I had to go up a jet size in my carb this year must be that ethanol or whatever else the gas companies are skimping on. And this year if my boat sits for 3 weeks 9 out of 10 times the front float is stuck closed.
PURPLE HORNET is offline
