Anyone know upper and lower gear ratiosfor No.6's >
Old 08-23-2009 | 08:53 PM
LubeJobs42's Avatar
Default Anyone know upper and lower gear ratiosfor No.6's
I need to know what the upper and lower gear ratios combinations are for different Number 6 drive ratios. Thank you!
1:24
Upper gear?
Lower gear?
1:29
Upper gear?
Lower gear?
1:35
Upper gear?
Lower gear?
LubeJobs42 is offline
Old 08-23-2009 | 10:17 PM
Call Vern Gilbert 310-995-1670.For a 1.29 and 1.43-they require the optional gear ratio in the lower only.So if you had a set of lowers with the optional gears-you could swap them with your 1.24 or 1.35 to create a 1.29 or a 1.43 respectfully.
skater40 is offline
Old 08-23-2009 | 10:36 PM
LubeJobs42's Avatar
Thank you! Are you going to Loto?
