Variable Pitch Prop >
Variable Pitch Prop
Variable Pitch Prop
Old 08-24-2009 | 08:26 PM
Default Variable Pitch Prop
Anyone have any words on a variable pitch propellor, "VPP"? I have one that came with my Scarab 22 that I'm wanting to set from 14p for hole shot, to 23p for top end....
I know that the individual blades can be expensive, but I guess the name of the game is, "don't hit anything"....
saltdog22 is offline
Old 08-25-2009 | 03:16 AM
General concensus on past threads has been that they are junk and come apart.
If you want to ski behind it, use a 5 blade. If you want top end, use a 3 blade.
Griff is offline
Old 08-25-2009 | 10:24 AM
FYI just my 2cts i had a areo 2 speed i think 18 to 23 i had it on a 24 baja bandit with a 502. i loved it you could blow jet skis out of the water and on plan in a flash. u can set it to change speeds at any rpm. i had it for 7 years never had a issue with it. Aero in hayden ID will retro fit it any way u want it. it was a kick in the rass prop and one heck of a hole shot.
Fever575 is offline
Old 08-25-2009 | 10:52 AM
I have heard a lot of positive's about this type of prop. I'm going to give it a try. It came with the boat, just not attached. It is need of some repair and wanted to kick the tires with the "board" to see if it would be worth the $200.00 dollars. I believe that you have awnsered my question....
Thanks a ton....
Sam
