502 mag timing!!!
Old 08-25-2009 | 04:18 PM
Default 502 mag timing!!!
I'm helping a friend work on a 98 502. I need some one that knows to help me. I understand taht you have to ground a wire or something out to set base timing but havent found anyone that can help me. HELP!!!!!
dragboatdash is offline
Old 08-25-2009 | 04:32 PM
KEPP's Avatar
Only the Best Will Do!
http://www.keitheickert.com/detail.aspx?ID=9227
KEPP is offline
Old 08-25-2009 | 04:41 PM
I have been told that you can do it with out the tool. Can anyone help me?
Old 08-25-2009 | 04:50 PM
You can jump the two wires in the dlc connector,
they're ajacent to each other, I'm thinking one is black
and the other is black/white, but I'll have to get
out the manual when I get home to be shure.
JaayTeee is offline
Old 08-25-2009 | 05:17 PM
If you wouldn't mind. Thank you. And were might this conector be?
Old 08-25-2009 | 05:32 PM
Is it carb or efi???
Boat Tech is offline
Old 08-25-2009 | 06:03 PM
efi
Old 08-25-2009 | 08:51 PM
I think a 98 might have a purple/white wire near the dist. if it does, jumper it to grnd to set base timing.
lookinforboats is offline
Old 08-25-2009 | 08:54 PM
forgot. it usually is not connected to anything and has a clear plug in the end of it. it is the est wire bypass
Old 08-26-2009 | 06:50 AM
Any body else have any imput?
