Best way to get 600+ HP???
My boat has a all stock 380HP 454 Mag EFI with thru-hull. What is the best way to get a reliable 600+ HP. I originally thought of a procharger, but have been thinking of pulling my 454mag and just poking in someone elses crate motor. I have no problem building a motor, but is a 454 bowtie block a good foundation to build a reliable motor, or should I get a big CID motor with more torque?
If your motor is a 454MAG EFI the block is not a Bowtie.
The only naturally aspirated Merc motor with a Bowtie block is the Bulldog. The Mag EFI is a standard Gen VI block.
That doesn't mean it's not a good foundation for a 600hp motor though. You could start with a 4.25 stroker assembly and a good bore will make a good 496 stroker motor that some here have made some really good numbers with.
Dave
Dave
Here is what I did. I started with a 454 bored and stroked it to a 489. New exhaust with long risers (no silent choice), RMbuilder custom cam. Good reliable 500HP. If you want more sell what you have and drop in a 540 or 572, start with a Dart or Merlin tall deck. You can easily build 600-650HP with that.
Sell what you have and start from scratch, been there. I did the Procharger and had good results with it but you will be better off starting from scratch with a 540. I added blowers, heads etc to some carbed 454 mags with good results. Both are options, but the 540 will be cheaper and more reliable down the road. A lot of stuff will have to be changed to do the Procharger right. If you build your 454 into more you will have a bunch of parts that you will have to give away. Again start from scratch and build it right.
