valve adjustment >
valve adjustment
valve adjustment
Old 08-30-2009 | 09:34 PM
Default valve adjustment
I set my valves on a new 502 by turning them 3/8 turn past zero lash on the heel of the cam. Now after I have run the engine through a heat cycle, the rockers seem alittle loose. (no ticking) I can spin the pushrods with my fingers on the valves that are closed. Is this normal
Brushwolf243 is offline
Old 08-30-2009 | 09:39 PM
what are you running roller rockers or stamped steel stock rockers?
zero lash then 3/4 of a turn works perfect you need for zero lash when running.... 3/8 is not enough. start on the base circle @ each rocker are you running a adjustable valve train the new stock vtr is non ajustable u just torque them to spec.
Rockfish71 is offline
Old 08-30-2009 | 09:46 PM
adjustable --- roller rockers
Old 08-31-2009 | 01:13 AM
Use 3/4 of turn after zero lash as stated. That is near perfect for the amount of preload needed.
Griff is offline
Old 08-31-2009 | 09:07 AM
Like these guys said, you need more pre-load than 3/8 of a turn. Some say 1/2, some say 3/4, so I adjust a little more than half. More like 5/8 of a turn. Crane used to have a good tech sheet on adjustment. Do a search you can probably find it.
jeffswav is offline
Old 08-31-2009 | 11:35 AM
DORaymond's Avatar
3/8 of a turn will be o.k. - in fact if the valves ever float, the lifters will not pump up as far and you could avoid major engine failure. With the engine stopped (no oil pressure) you should be able to turn the pushrods where the valves are closed, not where they are open.
DORaymond is offline
Old 08-31-2009 | 11:03 PM
If you will read your books and read from almost all cam manufactures..they say 1 full turn after all the slack is out of the rocker arm.
pslonaker is offline
Old 09-01-2009 | 01:42 AM
Hyd lifters need about .040 of preload. 3/4 of turn after zero lash is about perfect to attain this.
Adjusting Hydraulic Lifters for Proper Preload
In order to adjust the preload, the lifter must be properly located on the base circle or "Heel" of the lobe.
At this position the valve is closed and there is no lift taking place. You will need to watch the movement of the valves to determine which lifter is properly positioned for adjusting.
1. Remove the valve covers, and pick a cylinder that you are going to set the preload on.
2. Hand rotate the engine in its normal direction of rotation and watch the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder's intake rocker arm. (Why? Because when the exhaust valve is just beginning to open, the intake lifter will be on the base circle of the lobe, the correct position for adjusting the intake.)
3. Back off the intake rocker arm adjuster and remove any tension from the pushrod. Wait a minute or two for that hydraulic lifter to return to a neutral position. The spring inside the lifter will move the pushrod seat up against the retaining lock if you give it time to do so. (If you are installing brand new lifters they will be in the neutral position when they come in the box.)
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at "Zero Lash". Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. (Again, when we see the intake almost closed, we are sure that exhaust lifter is on the base circle of the lobe.) Loosen the exhaust rocker arm and follow the same procedure described before in steps 3 and 4 to adjust this rocker arm.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again.
Griff is offline
Old 09-01-2009 | 10:02 AM
bcfountain's Avatar
Registered User
this was the way i learned years ago and is the easyest way to do it.i belive the method is called split over-lap adjustment
bcfountain is offline
Old 09-01-2009 | 10:15 AM
lake speed's Avatar
not necessarily. my comp .300 taller hydraulic roller lifters came with directions that went totally against everything I have ever known when it comes to adjusting hydraulic lifters. Comp actually reccomends 0 to 1/8 turn of preload after the push rod stops spinning saying that any more than 1/8 turn will damage the lifter? I dont know why I read the directions on this one occasion but I am glad I did lol
lake speed is offline
