borg warner 10:18 parts wtb
where can I buy heavy duty internals for one. the reverse cluthes blew when the engine went. if anyone knows why that would also be a plus. bsides that where do I get performance replacement parts. bam is sucks more then a hoker in heat so anywhere but there. thanks
mike
mike
Reverse clutches went puking out happen'd when the engine blew from what im told. SO i need a basic rebuild clutches plates gaskets kit o ring kit output shaft input shaft seal kit and the output shaft bearing is no good,noise. But all else is good. O yes and also the reverse spring went for a ride to. Its all torn down cleaned and ready for assembly. Is there HP clutches and so on or is it just stock 7 plate stuff.
Mike
Mike
http://www.marineengineparts.com/
Check out this place. They have master rebuild kits and other parts for Borg-Warners.
Go to Drive Systems then Inboard Drive Systems.
Mike
Mike
Thanks dan/ken. Chris sent me a PM of a rebuild kit coast and outputshaft bearing price. I want to rebuild t next weekend after the Fairhaven run. Are they factory clitches or HP or is there no such thing as HP
-Mike or Novaboy71aol.com
