496 mag ho runs terrible after recall work >
Old 09-03-2009 | 07:09 PM
Default 496 mag ho runs terrible after recall work
Looking for help. I have a 2003 merc 496ho mag in my wellcraft excalibur, never started untill 2006. Ran like a top untill this spring with 80 hours on it. It had the aluminum water rails and they corroded off in that short of time. I found this was a service or recall issue and merc. shipped new manifolds and they were installed by a local merc. service marina. The problem is every since they did the work my boat runs terrible with missfires, backfiring and no power. I took it back to the marina that did the work, they put new platinum tipped plugs as required for the boat and labor at 600.00, boy did i get ripped. The boat ran fine for about 4 hours of run time and is now back to running terrible again. I have added yamaha ring away to the fuel to unclog any carbon, new fuel and seperator, had a mechaninc check all 8 coils, wires and plugs which all check out ok. On a compression test one cylinder is about 20psi less than the others. Totally stumpped here have a nice boat but cant use it and cannot diagnose the problem. Any help would be greatly appreciated
sunman496mag is offline
Old 09-06-2009 | 09:30 AM
Is the transom getting really black? Do you have any alarms sounding? If they didn't replace the temp sensors in the manifolds or you have a problem with one of them, It is maybe going into service/limp mode.
speedreeder is offline
Old 09-21-2009 | 04:42 PM
get it scanned,,,or yull throw money at it,,for nothing
TWIN-SPINS is offline
Old 09-27-2009 | 11:14 AM
monstaaa's Avatar
as stated get it scaned . you may also find no codes but yet still runs crappy.i have found a rah of bad injectors this season due to the fuel. doesnt show up on scan. and if checked with the injectors pulled out there is a spray evident, but it is not sufficient. check fuel amount with a beacon or adequate measureing cup. then swap injectors.
monstaaa is offline
