what are most of you guys running for flywheels ? >
Old 09-04-2009 | 09:51 PM
Default what are most of you guys running for flywheels ?
I have to have my rotating assembly balanced this week coming up
and I went to get my flywheel out of the shed and I forgot how heavy the damn thing was when I took it off
I have a Gen VI 454 motor and Bravo drive setup
is it possible to use a flexplate ?
or even a lightweight flywheel like you would on a manual trans setup in a car ?
let me know what you guys are using thanks
motor should put out close to 550 hp when done also
cbellamore is offline
Old 09-04-2009 | 10:50 PM
The heavy stick shift type flywheel.
picklenjim is offline
Old 09-05-2009 | 12:14 AM
http://www.jegs.com/i/GM+Performance...96987/10002/-1
Rockfish71 is offline
Old 09-05-2009 | 10:13 AM
Use the heavy flywheel. There is a reason for it, somone else may have the answer.
jeffswav is offline
Old 09-05-2009 | 02:39 PM
okay so I should keep the one that came on the motor then
or you would recommend going with the GM one in that link from Jegs,
Old 09-05-2009 | 08:06 PM
The one that came on the motor. It's probably the same thing anyway.
Old 09-06-2009 | 12:57 AM
I actually use a heavier Hays billet steel flywheel. It is heavier than the cast iron one you have. I will use a cast iron flywheel until about 750 hp. After that, I go to the billet steel.
With the engine going in a boat, you need the inertia of the heavy flywheel when you put it in gear. If you used a lighter flywheel, you would have problems with the engine wanting to stall when you go into gear.
Eddie
Young Performance is offline
Old 09-06-2009 | 04:54 PM
Eddie
Okay thanks for explaining that to me it makes sense
Im only planning on around 550hp so i will stick with the stock one,
my boat originally came with an alpha setup and Im now switching over to a Bravo setup,
the bolt pattern should be the same for the drive coupler between the alpha and the bravo right ?
Old 09-06-2009 | 05:33 PM
Default mrfixxall
yes their the same but with 550 hp your going to have to change the coupler to a hp one..your also going to have to get the flywheel ballanced to your bottom end unless you didnt ballance your rotating assembly..if they internallt ballanced your assembly then theirs a whole different way to approach the ballancing method..you may have to change to a 427 style flywheel and harmonic ballancer..
FIXX is offline
Old 09-06-2009 | 08:27 PM
okay I'll look into the HP drive coupler
Im having the rotating assembly balanced before assembly which is hopefully in another week or two
thanks for the replys
