IAC for a 525 Design I or II  ? >
Old 09-08-2009 | 07:13 AM
25 hors la loi's Avatar
Default IAC for a 525 Design I or II ?
Since my idle surge +/- 200 rpm , i look to exchange my IAC , but need to know what is the difference in the Design I or II , it`s the same things ? part 15 and 16 ?
Many thanks in advance
25 hors la loi is offline
Old 09-08-2009 | 07:26 AM
Just to add note , the problem is , the motor working great , but when i put trottle off , the rpm stay at 800- 1000 , and after 15 to 30 sec they go back to 600 , this is why i think is my IAC ,,,that made sense ?
Old 09-08-2009 | 09:13 AM
Default mrfixxall
Get a can of throttle body cleaner ant your local ap store,if your throttle blade is built up with oil and carbon it will hold the throttle blade open which will cause it to surge,also it will throw the tps % off then the pcm will think the throttle blade are not closed...
FIXX is offline
Old 09-08-2009 | 07:48 PM
Many Thanks i will give it a try ...you remove the little air filter and spray it inside ?
Regards
Old 09-14-2009 | 07:46 AM
Many thanks for the hint , they work very well
Attached Thumbnails IAC for a 525 Design I or II  ?-p1060442-%5Bdesktop-resolution%5D.jpg
