winch strap help
Charter Member #415
Straps have either a bolt that goes across the winch drum,or a tapered tail that you thread out and in the large holes on one side of the drum,then wind the strap over the tail You can drill 2 holes for the bolt,better choice is cut the bolt loop of and roll the strap up to thread thru the side holes. Or you could just buy a new strap with the tapered tail.
thanks i found this page http://shop.easternmarine.com/downlo...nch_strap2.pdf
and drilled hole and put grade 8 bolt.
